I need immediately file repair doc utility.
Asked By 25 points N/A Posted on -
Hello all, I am new in computer side and I do not have much knowledge about MS Office. I have some corrupted Word document and I badly need to repair.Can you tell me what is the best file repair doc tools or software. Please describe in details and do not ask any question. I used in my Computer MS Office 2007.
Answered By 45 points N/A #170791
Hello there Herbert,
I know you are having  a hard time fixing your corrupted word file but as I search on Google on how to fix this office files, there are two ways, either to use the free and simplest way or to buy the software needed to repair those files. If you want to use the simplest way, just visit to refer to the article that http://www.thatdanny.com/2008/07/07/how-do-i-repair-a-corrupted-word-file-corrupted-microsoft-word-files-that-wont-open/ has created for those users having same problem with you or you may download Word Repair software to fix you file, a software that is widely use to repair corrupted word files.
Hope this helps you.
Regards, Roland.
