Does the Linksys client VPN only works with Linksys routers? Where can I download the software? I have tried seeking help to Linksys support but none of my questions were entertained. I hope I can get quick response on this problem.
Thank you.
I need information on linksys klient vpn
Hi Bernard Fleck,
You can download all Linksys products from here http://support.linksys.com/en-apac/support/linksys and also you can ask questions in their support center. After downloading this software, click on open.
When you open the software it will ask you to agree their terms and conditions. Just click ok and click next, next. It will be installed fully. I think it will help you very much.
Thanks.Â
Hello Bernard Fleck,
Linksys is a popular wireless router which is a part of Cisco system. VNP is a way to connect the Linksys wireless router.
You have to get a VNP router and software to connect with VNP clients because Linksys is only capable of enabling the VNP pass through device.
You can download Linksys from here and for further information and setup you can check on the site Linksys knowledge base. Hope this could be a help.
Good luck.
