Mark E Ward
30 points
Posted on - 03/24/2013
Hi everyone,
I have managed an internet server. I want to limit the use of the internet. Is there any good software of internet limiter for wireless network? Please inform me as soon as possible in reply.
I need an internet limiter software
Hi there,
Start> Run, type gpedit.msc and confirm. Then Computer Configuration> Administrative Templates> Network> QOS Packet Scheduler. Thereafter, the limit reservable bandwidth> tab "extended". Then, access the link "properties" and then:
– Point "activated" and limit bandwidth 80% (as you like here)
– Ditto following: limit the number of packets queued> small number
– Next: a low value for the time
And finally apply the changes.
If not satisfactory, you can also log on to your cable box via a couple of "CPL" through the outlets. Your cable connection has a certain priority flow on WiFi.
