thomas
10 points
Posted on - 12/01/2012
I need an internet speed test monitor. I am running an internet café with 52 computer units. I have to monitor each computer’s internet speed so that I would be able to maintain proper service to my customers. Business is very important and we cannot take for granted the needs of our clients. I hope you can give me some information on how to have internet speed test monitoring software.
Thomas.
Hi Thomas,
There are several ways on how to test your internet speed connection. Here are some of the following:
1. You can test your internet speed connection via online. This kind of test van measures your internet connection by sending data from the server and receiving data sent by the server.
Example:
http://www.speedtest.net/
www.bandwidthplace.com
www.speedtestonline.com
2. You can test your internet connection via installed speed test application in your system. Just like the online speed testing, it requires an internet connection to do the testing.
Example:
Broadband Speed Test Software
Hi Dear Thomas,
I read your question but it is very simple to answer it.
There are a lots of speed test servers are on the web.
But i am going to share a very best speed test monitor. It is more accurate than any other.
http://www.fun92.org/internet-speed-test.php
When you will check this site you will get a Begin Test button. Just click on that button and wait till results. It will check the time to Ping, Download Speed and Upload Speed.
You will enjoy it.
Thanks
If you want an internet speed monitoring application for every computer you have on the network, what you probably need is a bandwidth monitoring tool. Try downloading NetWorx. It is a bandwidth monitoring tool that you can use to evaluate every computer’s bandwidth consumption. It can be used to collect bandwidth usage data and measure the speed of your internet and any other connections.
Unfortunately, the application is no longer free after it was commercialized by the developer. The last freeware version of this tool is NetWorx 5.5.5. Versions after this are no longer free. For pricing, visit NetWorx Purchasing Information. Prices vary by number of devices covered. The latest version at the moment supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10.
For servers, it supports Windows Server 2003 until Windows Server 2016. The trial version works full featured for 30 days.
