I need an iPhone 5 software for budget and bill paying
Hi.  Can someone here suggest an accurate mobile software for budget and bill paying?  I have the 16 GB iPhone 5 that has the Apple A6 chipset, Dual-core 1.2 GHz CPU, PowerVR SGX 543MP3 GPU and iOS 6.1.2.  Any suggestions would be much appreciated.
Best Answer by Burton Studebaker
Answered By 0 points N/A #144124
Good day Effieclyde,
It is really a good thing that you have something that helps you manage your daily finances especially when it comes to budgeting and bills paying. Well, I recommend this compatible Apple iPhone 5 applications to help you out.
TOSHL
If you need a simple, secure and intuitive way to keep your finances in order, this is the app that everyone keeps talking about.
This app is definitely FREE. It provides clean iPhone expenses tracking that is very easy to use. It also offers a great upgrade like multiple user support for family budgeting. You can also export it to Excel, PDF, and Google Docs.
Here are some screenshots below.
I hope you like it.
Enjoy!
Answered By 5 points N/A #144126
Hi Effieclyde,
Not sure if you have this app in your IPHONE but normally this should be preinstalled in your device. The name of the App is MINT. This is one of the top rated applications best suited for managing your expenses, setting up goals, setting up budgets and much more. One good thing about this app is that it connects to your bank (given that your bank account is supported) and download your transactions. All you need to do next is to categorize your transactions and the app will take care of the reports. Check the image below:
You can learn more about this app from www.mint.com. Hope this helps!
