I need a Jpg to mif image converter
Hello fellow members.  I have a JPEG image that I would like to convert to an mif image so I could put it in a FrameMaker application.  Can someone suggest a JPG to mif image converter?  I am on Windows 7 64 bit if that matters.
Answered By 0 points N/A #198417
Hi Douglas M Scott,
There is an application that is available in the Internet that allows you to convert .JPEG files into .MIF format, the software is called 'Ivan Image Converter'. This Ivan Image Converter software is capable of converting picture files into different formats regarding on your desires. It also has the capability to do a batch processing so that you won't get hassle clicking the image and converting them one by one.
