I need JQuery plug-in for 360 image rotation in flash player
Hi guys.  I'm trying to make a 3D interactive Flash website.  Where can I find JQuery plug-in for 360 image rotation in Flash player?  I'm on Windows 7 64 bit and I use Mozilla Firefox as my browser.  Thanks in advance.
Answered By 60 points N/A #135545
First of all, All the very Best for your website.
As you mentioned you are using jquery for your webpage and you are looking for some plugins for 360 image rotation, I will recommend you Ajax Zoom, it is a very well functioned tool which will provide you zoom with 36o image rotation. It uses Image Pyramid technology and also allows you to rotate on Z-axis .
Hope you will have good time with this tool.
