Hello techyv.com!
I need to make some media and text files and I was required to use juniper font. Please tell me how can I get this juniper media font, and please orient me on what software should I be using that is compatible with this. By the way, I'm using a laptop with OS Windows 7. Thanks!
I need a juniper media font for my adobe
This is easily available on many sites and you can install it to get the best graphic results as required by you.
I can help you in finding the font and applying it to your graphics.
You can install this font by installing the package of all fonts for windows.
You will be able to find the font in all font collections or simply visit one of the links below to get the specific font:Â
UrbanFonts Link
Font Zone
Darrel R Gonzale
Hi LUKE,
Juniper fonts are best available on Adobe. This software is not free but if you’re a professional it’s the best choice for you.
I have attached its picture so that you can gain a rough idea how they look like, if you wish to download this software than visit.
I hope your problem is solved now as this software is the best for media and text base files.
