Leon Fra
5 points
I need to know about array formula in Excel
Hi
Since you are seeking results based on a single criteria (“count the number of times the value in a cell is greater than 0 for a particular row or column”), the COUNTIF function could be used. You would highlight the range (rows and columns) and use the following formula: =COUNTIF(A1:C3,">0")
See picture below for illustration:
If you were using more than one criteria, the array function would be needed. An array formula simplifies several Excel calculations into one cell. This means, that complex related to
Counting characters in a select cell range
Sum of numbers that meet a criteria
Sum of nth value from a selection (range) of values.
Array formulas are also known as "CSE formulas," i.e. the CTRL+SHIFT+ENTER keys that are pressed to activate the function in your workbook (COMMAND+SHIFT+RETURN on MacIntosh systems). In Microsoft Excel, the curly brackets {} are automatically entered when you select the CSE keys.
Array formulas is one of the powerful tool in Excel sheet. It mainly works with array, series of data or multiple data values and is not working for the single data value. Some of the array formula's we have SUM, AVERAGE or COUNT.
Yes, you can use the Count function for this.
