I need to know how to do the powerpoint addin ocx?
Hi
I need to prepare some professional and attractive PowerPoint slides for my main presentation. I need to know how to do adding OCX to the PowerPoint. I also need to know where I can get those from internet.
Thank you
Best Answer by Herring Thatr
Answered By 0 points N/A #138863
If you go to http://www.officeocx.com/PowerPoint-Viewer-OCX.htm you can find a tool which was specifically created to solve the above mentioned problem.
You can download a link from the website which provides OCX with new solutions and possibilities to use at Windows Powerpoint.
There is another choice at https://www.edrawsoft.com/office-ocx.php offering a solution.
Answered By 0 points N/A #138864
If you’re using PowerPoint 2007:
Open PowerPoint and click the circular Office logo in the top left corner.  At the very bottom of the menu, there is a button that says “PowerPoint Options.”  Click it.  There will be a checkbox that says “Show Developer tab.”  Check this box, then click “OK.”  Now you can click on the “Developer” tab, and all the controls will be in that tab (they appear as small icons, so you may have to scroll over them to find the one for OCX).
If you’re using PowerPoint 2010:
Open PowerPoint and click on the “View” tab, then click “Toolbars” and “Control Toolbox.”  In Control Toolbox, select “More Controls.”  Near the bottom, there should an option for “Register Custom Control.”  Select that, and locate the OCX you want.
