I need to know how to download and work with Mini PE.
Hallo! I have no idea what has happened to my computer. I have been trying to boot my computer but to no avail. This triggered some memory of a bootable CD that I can use to boot my PC and recover my data. Yes, it is called Mini PE! My biggest worry is that I have no idea have to get that CD and the procedure of working with it. Kindly guide me on how to go about it. Thanks!
Answered By 35 points N/A #155920
Firstly, you can try to boot your system using safe mode. This will boot your system and once booted you can use a pendrive to recover your data which is not been LOST already.
To start your computer in safe mode-
1) Turn on the system and keep pressing F8 until you get a screen with some options in it.
2) Choose safe mode and hit enter. This will start your windows.
Mini pe is a bootable cd which has a lot of features like antivirus programs, data recovery programs and so on.
I would recommend you to Hirens boot cd. It is much better than mini pe. All you have to do is download the ISO file, burn it onto a CD, place this CD into the CD ROM and restart your computer. That's it!
Look for a program called Malware Bytes and run it, this will fix your boot problems and remove all the virus's as well.
You can download it here- http://www.afterdawn.com/software/system_tools/operating_systems/hirens_bootcd.cfm
