I need to know How to enable telnet astaro firewall
Hi I am a new to this field and I got my first project at work to maintain the astro firewall in my company. I need to know How to enable telnet astaro firewall. I do not work with astro before. Help me to do this. Thank you
Best Answer by Vinson forman
Answered By -5 points N/A #147068
If you have not worked with Astaro before, here is a link from their official website which will help you a great deal in enabling telnet Astaro firewall.
www.astaro.com/getting-started/getting-started-guide-lm-en.pdf
I hope this helps you out.
Answered By 0 points N/A #197377
Hi Dear,
Your Problem is not more complicated but only if you have worked before with the ASTARO Firewall.
First please get all the information about your  Network. Means to say that you should have to know about your network's Clients addresses, Server IP Addresses and other basic Configurations about the network.
Now See that
These are the contents of Astaro Security,
Network Services & DNS
Forwarder
Request Routing
Static Entries
dynDNS
You have to set your DNS first, after that Forwarder settings and all those which are given above…
For more information visit this Link
https://www.sophos.com/en-us.aspx
