I need to know how to hide contacts on my blackberry messenger.
Yes dear, hiding a contact on Blackberry messenger is easy. First of all find out the contact you want to hide and select it. Now go to setting and you will find “Never show”, click on it. You are done. This process will not delete your contact and you can edit for a specific time period.
Hi there user:
Yes. You can do that using your Black Berry. Just enable the ‘never show’ button in your phone-contact when you add contact you want to hide.
But let me just remind you that (most) Black Berry users were aware of that option. Especially those people who frequently consult their manual.
The best suggestion I could give you is to make a filter called ‘hidden’ in your contacts, add the contacts you want to hide to that filter, then hide the filter.
Thanks for asking question here at techyv.com
Best regards,
