Hello,Â
I am currently moving my data marketing company to the cloud and would like to disable drive lock for a moment while I do this. I want to see my data in its most crude form. How can I go about this, readers?
I need to know how to turn off drive lock
There are many possible ways to disable drive lock. It depends on the kind of the lock, on which way you shall disable it. you can disable drivelock in the following way. You can enter system bios and security settings to do this. You can do this when you start your pc. But this shall not work when you restart the pc. However, try the following:
1. Enter security settings
2. Enter DriveLock passwords
3. Enable/disable DriveLock
4. Change a DriveLock user or give a master password.
5. Now, DriveLock Settings are accessible only when you enter pc.
Hope this helps.
