Hello Experts,
I need to know how to uninstall up to down? The plug in was attached in my Google chrome and I want to get rid of this thing for I did not download this stuff it just came up when I am downloading something maybe I clicked it by mistake. I hope you can give me a way to uninstall this.
Thank you.
I need to know how to uninstall upto down?
Hello Martha,
I can understand how irritating it feels  when such a stupid plugin stick to our computer and disturbs us. The best way to get rid of this plugin is to uninstall using a software "Revo Uninstaller".
This software helps you to completely uninstall the program and remove all the associated files with it.
Hope this would work.
I can tell you a way to uninstall the required plug-in. You need to follow these instructions.
Go to start and then to control panel
From there go to Add remove programs and find the desired plug-in here you want to uninstall.
If you find the plug-in here then click on it and then click uninstall. You will be able to uninstall the plug in.
However if you don’t find it in Add remove programs then you can do the same thing with your browser you are using to surf the web.
Smith Thompson
