I need to know more about IRIS Explorer
I would like to know more about IRIS Explorer. For example what platform is used by IRIS Explorer? What are its technical requirements in terms of software and hardware? Is there anything that can affect performance of IRIS Explorer on my PC? I would also like to know the standards that are used in the development of IRIS Explorer.
Best Answer by sauivhoi
Answered By 0 points N/A #109277
For those who need a powerful and flexible 3D visualization application, IRIS Explorerâ„¢ is the most advanced visual programming environment for 3D visualization, animation and manipulation available today.
Its easy to use point-and-click interface means that users spend less time programming and developing customized visualization applications. The extensive library of 'modules' (software routines) included puts a wide range of advanced visualization and analysis techniques at users' fingertips. Simply select modules from the library and connect them to interactively read and visualize data for analysis, presentation and publication.
Answered By 5 points N/A #109278
The iris explorer is a visual modular software that uses render module.develop by NAG Ltd.first you need a Unix or windows NT.operating system.a good graphics card it's a nice software this software use by some student in engineering student for some science project visualization purposes and group analytical data in some projects.
