Hello experts,
I need to know test case for projector in testing. What is all about testing a projector? How will I be able to know if the projector is working fine and no defects at all? I hope you can give me the best information related and regarding this issue. Your suggestions are most welcome.
Thank you.
vijilp
Hi, Below are the some functional and usability test cases for the projector testing. These below cases ensures that projector is in the working condition and basic functionality of projector is working.
1. Actual Test: Verify that when a projector is connected to a external device like computer and when turned on the display of the projector is proper. Expected: Projector display is proper and the input from the connected device is displayed.
2 Actual Test: Verify that all the display functionalities of a projector like brightness, Color,Contrast are working. Expected: Able to adjust the display functionalities of the projector.
3. Actual Test: Verify that able to adjust projector's output display. Expected: Able to adjust projector's output display.
Vijil
There are some basic tests that determine the projector is working at its optimum level. You have to check proper and uninterrupted power supply and a flat stationary surface. Image quality is checked by emphasizing a particular area of presentation such as color accuracy, image homogeneity and text readability. The projector should have a great throw ratio which enables it to display a large picture in a small room from a small distance.
