I need lego webcam 64 bit driver download
I am using an old Lego webcam.
My computer was running on 32 bit operating system but now I am running 64 bit operating system windows.
So I need lego webcam 64 bit driver as it is not working now.
Where can I find it?
Best Answer by Pagee Stephen
Answered By 0 points N/A #184725
Hi Thomas,
As you are running Windows on 64-bit architecture, 32-bit supported driver software won't work. For help, you can take a look at the official Logitech Forum where this issue is discussed. Read the thread carefully.
You will find links to various download links and support pages.
If you feel that you need any more help please contact.
Regards
Answered By 10 points N/A #184726
Hey Thomas, Hello there.
Well you can always download the latest drivers from the manufacturer's website by checking the model number.
Usually the equipment manufacturers update their websites whenever there is a new Operating System update.
The other option would be go to this link and download the software that supports your webcam.
Regards Ian M Tyner.
