I have been working as an administrative support online via home based.
My Work is different from the time in US and my time here which is Philippines and I always forget our differences in time in terms of the time zone.
So please help me if it is possible to link my clock ms into some other timezones other than mine?
Thanks!
I need to link my clock ms for other country time
Windows 7 has new improved clock task bar from previous version.
You can use the following Clock Systems Tray Method:
The systems tray displays an analog clock showing time, calendar and your current date.
You can adjust the time by clicking the Change date and time settings:
If you need time in different time zones, you may select Additional Clock Tab.
You can add up to 2 or more clocks. You may select the time zone you want to display.
If you choose the clock in the taskbar, you'll now see 3 clocks, you current time and date which is the bigger one and the other two clocks are time zones you wanted to display.
