I have an iMac with the quad-core Intel Core i5 3.02 GHz, NVIDIA GeForce GTX 680MX graphics and OSx Mountain Lion. How can I manipulate the camera to be a face recognition-enabled computer login utility and a motion sensor security camera? I need tips for Mac webcam manipulation. Thanks.
I need Mac webcam manipulation tips
You can change the settings for the Macbook Pro's built in webcam. Generally Apple apps make the automatically iSight settings and do not allow you to manipulate them from your application. For using Skype through your webcam, you can change settings which is suitable for you. To know more about it you can visit this link : http://resale.headgap.com/bobsmactips.html
You can know about other essential tips for MAC user. Thanks.
