damon healy
30 points
Posted on - 03/25/2013
I just installed Bizagi Process Modeler for creating flowcharts to outline every aspect of my business.Â
I would like the charts to be exported in PDF and XPDL file format.Â
I need the manual Bizagi Process Modeler.Â
Please help.Â
Thanks in advance.
I need manual Bizagi Process Modeler
Hi Healy,
The Bizagi Process Modeler is a tool that is easy to use in process modeling and process management tool.
Check this video tutorial maybe it can give you idea in using Bizagi Process Modeler.
And download the link below, that link is a Bizagi Process Modeler User's Guide.
The words are in Spanish just scroll down and click the Guide in English.
Every process can be shared with ''Bizagi Process Modeler''. You can export, import or even share with this program. To export a PDF or a XPDL file you have to find the Presentation Mode and then the export option. You choose the kind of file that you want. The Presentation button is at the bottom of the page.
