I need Microsoft ISO tool windows 7 for Burning ISO files.
Hi buddy,
I need to burn ISO Image in Windows 7. I want to do this without using third party tool. I want to Burn in ISO image on CD just by right click. I hear about such type of tool from my friend. I found very complicated solutions when I searched microsoft iso tool windows 7. Please tell me the exact location from where I can get the best solution. Or give me step by step instruction to do this.
Answered By 10 points N/A #166787
Hello Mr. Hodge,
An ISO (International Organization for Standardization) image is an archive file or it is also known as an image file. Windows 7 has native supporting ability to burn ISO images directly without any third party tool.
To burn an ISO image in Windows 7, You just need to right click on an ISO image and choose burn disk image.
Windows Disk Image Burner, this launcher will give you the option to select CD or DVD.
There is another option where you can check or uncheck "Verify Disk after burning". If you check this box it will take additional time, but it will make sure the ISO image burned correctly. But if you are in a hurry, just uncheck it.
If you choose to burn ISO images on a DVD-RW disk, for that Windows disk image burner has a great feature, that it will detect automatically,  you have any content on DVD-RW and it will ask you, if you would like to erase the disc and burn new content on it. This ensures accidental erase and burn over something important that may be on the DVD-RW.
Then just press “burn”.
If you want any third party burner, Check the link.
Hope this would help you.
