I need the most recent anti-virus for my laptop..
I need the most recent anti-virus for my laptop. Can you help me decide what to use?
Site the advantages and disadvantages please.
There are various anti viruses that you might want to choose from, all which are latest and strong anti viruses. I will break to you some that I have been able to use before and they are just the best. They are the following:
Some notable features in these antivirus applications that offer protection to your computer are the link scanner that will scan every link you access online for any potential infections, the identity protection feature that protects against malicious applications executing on your computer. The way to get the best services from an antivirus is to ensure that it is always updated to be strong enough to counter viruses.
-Expert techyv
There are lots of Antivirus on site but i suggest you use the latest NOD32 Antivirus 5.0.95 because it has great performance. And compared it to other Antivirus online it's not heavy to download since it is only 50.14MB. ESET NOD32 Antivirus is the most effective protection you can find to eradicate large volumes of Internet and email threats. It is using advanced Threat sense technology that protects your computer from new threats.
NOD32 Antivirus detects known and unknown viruses, Trojans, worms, adware, spyware, rootkits and other threats. So simple and effective software to protect your computer. Here is a sample link where you can get the NOD32 Antivirus. Just download it then install. After installing, you scan your computer for unknown viruses, trojans, worms, adware, spyware, rootkits.
A piece of advice, always update your NOD32 Antivirus so that it can detect new threats, Since everyday there are lot of new viruses. I hope i did helped you with your problem.
Enjoy!
