I need a sound software for my mouse that can enable or disable clicking sound and have the ability to add a personal wav file sound effect. My PC runs on Core i3 and Windows 7 64 bit. Can anyone suggest mouse click sound software Windows 7? Thanks in advance.
I need Mouse click sound software windows 7
Hello there,
Everything you need to turn on/off clicking sounds on your Windows you already have.
Right click on the speaker icon in the taskbar and select Sounds. New window will pop up giving you plenty of sounds for every single action including mouse click.
To create your own sounds there is very nice and simple software called iFX Seven Sound Creator. it is a pretty straightforward utility that will guide you through the whole process of creating and saving your sounds.
To enable or disable the sound from your mouse, open your Control Panel and click the Sound icon.
Under the Sounds tab, you can configure which Windows event and programs for which you want to enable or disable the sounds.
If you want to add sound effects to your mouse cursor, try About UberIcon.
It will add effects to your mouse when launching your icons and folders.
Another software is CursorFX. You can download the trial version of it.
