I need an NEN assemble a PC on my network
Hello Experts,
I need an NEN assemble a PC on my network at (https://www.mifcom.de/) and don't know exactly whether the components match as well and run smoothly together, or whether the 650W from the power supply is sufficient for this configuration or if I need another power supply need it. In addition,
I'm not sure whether it differed in two large graphics cards are able to fulfill my requirements. But I Would be glad if you can advise me on one of them. The TI version is about 50 € more expensive for me and I do not know whether I need it.
Graphics cards are available:
1. NVIDIA GeForce GTX 560 1024 MB
2. NVIDIA GeForce GTX 560 Ti 1024
 Computer compilation (graphics cards would then vary depending on the result):
Specification of my computer is as follows
- CPU (Processor): Intel Core i7 960, 4x 3.2GHz
- Motherboard: Gigabyte GA-EX58-UD3R Intel X58 (USB3.0/SATA3)
- Graphics Card: NVIDIA Ge Force GTX 560 to 1024
- Memory: 8 GB Kingston HyperX DDR3-1333 CL9
- Hard Drive: 1TB Samsung Spin point F3 32 MB cache
- SATA2 Drive: LG GH24NS70 24x DVD Burner
- PSU: 650W – Corsair TX-M Enthusiast Alternatively
- I would even have this Power Supply Prefer: 650W – LC Power Green
- Power Body: IN WIN – Mana 136
- White Sound Card: Onboard HD Audio
- CPU Cooler: Orig Box
- Cooler Fan Control: No / integrated in the housing (if available)
Thanks in advance.
