kent woods
30 points
Posted on - 09/09/2012
I need a nti codec activation for my installation in my current computer with an operating system of windows 7 32 bit. Need your help experts, I can’t install nti media maker without an activation code to continue the installation process.
That activation code you are saying for the application you have is really important for the program to work again. This is mainly used to activate the product after the trial period has expired. You reached this part of the product probably because the total amount of time that the software has allotted for the trial period has already been consumed. This is the part where the application disables itself and will now ask you to enter the activation code for you to use the product again.
The best option here is to buy the activation code or the CD key, from the software’s official website. But doing this will require you to pay a certain amount of fee for the activation code. After doing the transaction, your CD key will then be sent to your email address which is specified in the form you filled out. Just check your email after a couple of days maybe then just apply it to your program.
