I need an online layout tools for pictures
Hello. Where can I find an online layout tool for pictures? How can I construct a wall layout and floor layout for my engineering project in this online layout tool for pictures? Thanks.
Hi Kurt,
You can check on Autodesk, this provides 3D design that can be used for planning and construction. It was best known as Autocad. I found you a tutorial that can help you start off your design just click the link here.
If you want to save up you can use your Microsoft Excel to design floor plans it may take more time but it can help you save a couple of box more information found here.
Edraw max is also a building plan software and download is free, Check more information here.
Try to download free applications from Google Web Store, under the category – productivity. You must use Google Chrome as your browser for this to work, select application of your choice then install (it will be installed as GC extension). You will now be able to layout pictures the way you want it.
The most professional tool that is required for all engineering courses is the AutoCAD (https://www.autodesk.com/)
AutoCAD is a computer generated design for Computer Aided Drafting (https://www.autodesk.com/products/autodesk-autocad/overview). It also comes in different courses for Civil Engineers, Electrical Engineers and Mechanical Engineers. This application can support from 2D to 3D rendering and can be used on planning and construction and it is easy to use and understand.
