I need Pdf to doc converter free
I need to convert a lot of PDF files to word doc files.
What is a good PDF to doc converter free that can do batch conversion and preserves all data?
I'm on Windows Vista 64 bit and Microsoft Office 2003.
Hello Christine,
The latest version of Adobe reader has the capability to convert the PDF file which can be found under Acrobat Online Services. To use this service you have to register yourself to the Adobe official website.
If you do not want to the registration to be done then there are lots of online services that offer the PDF to word conversion for free.
Please visit any of the following web links mentioned below:
1. PDF online Download PDF-to-Word for your PC
2. PDF to Word
The procedure is simple just upload your PDF file then press the convert now button.
This will convert your file within few minutes depending on the size of the file, save it to your computer.
Thanks
ZamZar is a very good online tool through which you can convert all your PDF files to Doc files.
It is an online tool so doesn't depend what Windows OS you are using and which bit.
Just follow the simple instructions displaying on screen and get all your PDF files in document format.
Below is the link..
Notifications
