I need a PDF to MS Word Docx converter.
Hallo!
I accidentally deleted my friends Microsoft Office Word documents from his flash disk. Luckily, he had the documents stored in the computer in PDF formats. I would like to convert the documents back to MS Word. What PDF to MS Word docx converter can I use? Thanks big time for your help.
Answered By 0 points N/A #151686
Hello Grant
You can use Adobe Acrobat. If you do not have Adobe Acrobat you have an old version, you need to download a new version because it is much easier to do the work for you. Using this link http://get.adobe.com/fr/reader/otherversions/ you have an updated version. For the conversion,
– Using the Acrobat you downloaded open the pdf file you need click ’’File’’ menu;
– Thereafter, click on save as
– Select Microsoft word from the next instruction demanded and further Word document to save your pdf to word.
You will better still be able to do it online with http://www.pdftoword.org/. If you have internet it will be much easy. Click the select button and choose the Pdf file to be converted and click Convert.
