I need a personal signature generator for my blog?
Hi guys.  I'm trying to make a blog site with my signature on every blog article I make.  Is there a personal signature generator that I could use and would it require additional hardware?  I have a desktop that is not touch screen and runs on Windows 7 64 bit.  Thanks in advance.
Best Answer by Drake Vivian
Answered By 0 points N/A #137244
 You may want to try this site www.mylivesignature.com it is a free signature generator  that you can use for your blogs. Then you may check also this site http://blueblots.com/design/online-signature-maker/ for a complete list of online signature generators. I guess you don’t need any changes on your operating system or you need specific application for download.
Answered By 30 points N/A #137245
Hi there Donna Davis,
One of the best and most popular online places to create your personal signature is https://www.mylivesignature.com/ so make sure to check it.
I would also recommend you to visit the following links:
They are all very simple web services that offer you the creation of your personal signature and they do not require any additional software or hardware.
Best regards,
Drake Vivian
Answered By 10 points N/A #137246
You can try this http://coolonlinetools.net/signature-generator/. This is just a simple signature generator you can use to create and custom your signature to post on your own blog. You can choose font style and add images if you want. Steps are just easy to follow and you don’t have to install any software on your computer.
