John L Krug
10 points
Posted on - 05/11/2013
Hi expert, I am using windows XP on my PC. I have some important photos and family photos on my PC. Some times my brother deletes several photos of it. So, I need a photo undelete program to keep safe my important pictures. Is that possible or if there any other ways to keep my photos safe?
Hi john
First thing and the most important do not modify the partion the photos deleted from , when you delete a file it is not deleted from the hard drive surface until modification and receiving new data on the same area
Secondly you can use pandora recovery program it is good for pictures and test disk but the second one needs an expert to deal with, its complicated a little bit
https://www.pandorarecovery.com/
And to prevent your brother modify your files you can use true crypt program, it enables you to make small folder for you protected with highly secured password preventing any one accessing it except you
http://truecrypt.sourceforge.net/
