Hi fellow members. Can someone here teach me a PHP and MySQL tutorial? I want to change and edit the design of my website which includes a forum or message board. What are the things that I need? I'm on a Windows XP 64 bit system. Any help would be much appreciated. Thanks.
I need PHP and MySQL tutorial for my website
Hi, editing and changing your website designs using a php and mysql codes are awesome. You just have to type in the right codes in order to successfully run your desired program. I've found a link here in which, you will find a lot of PHP and MySQL tutorials. http://www.good-tutorials.com/tutorials/php/forums
Hi Dudley
This is the best way for you to start or improve your PHP skills
You just need to download the software and install it on your computer.
For MySql, take a look at this.
Come back if you have any other question
