I need someone to help me in PHP coding avatar. I'm going to use PHP Thumbnailer Class. I'm trying to upload a picture in JPEG format into a coded image upload script that should automatically resize it to 100×100 pixels. How can I integrate it in PHP log-in script?
I need Php coding avatar tutorial
Hello Mr. Williams,
The main goal of this tutorial is to upload a picture or avatar to their profile page. It will automatically shrink the image to your desired dimension.
Requirements:
PHP login script.
Hope this will help you.
Thank you for your question.Â
Hello Mr. Todd Williams,
The main requirements of this problem are upload a picture and PHP login script and PHP Thumbnail Class.
From PHP login script click PHP Login Script :: Free PHP/MySQL Login Script with Remember me
For PHP Thumbnail Class click Thumbnail class PHP
For upload a picture click here.
I hope this will fix the problem.
Thanks & Regards
Gillam Janetj
