Hi guys. I just purchased a PhpBB template that has an admin panel for the website that I'm going to create. Is there a PhpBB theme maker that I could use? I want it to have a more personal look. I'm on Windows XP 64 bit SP 2. Thanks in advance.
I need a PhpBB theme maker
There a number of phpBB3 theme makers that you could use from the http://savedwebhistory.org/k/phpbb-theme-maker website. From the website, you can also get a number of phpBB3 templates, image sets, styles and themes. The amazing thing with phpBB3 is that the codes are separate from the files making it easy to change the themes.
   Yes there are online software available that can help you in doing this task and some of them are freeware too.
Here is the list of sites that can help you doing it. The Colorize it site site offers online theme making and they have many unique features too. The style on the other hand does the same job but with a different style they provide with many online themes and changing can be done online too. Please try them both. More can be found on Google.
Please check and download the one that is appropriate for you!
1. Colorize it site online maker.
2. Style themes online.
Please use the one that suits you!
Hope you got your answer! 🙂
