To whom it may concern,
Hi everyone! I needed help regarding my files on the desktop.
A virus has inserted in my computer through a flash drive. All my files were placed into the shortcut. Do you know a portable ext3 data recovery I can use for this.
Thank you so much!
I need a Portable Ext3 Data Recovery for files recovery.
Hello Carlson,
Nowadays flash drive is the most important thing for our daily work but sometimes we got into trouble because of this. I think UFS Explorer would be a good choice for you to recover files cause it supports a variety of file systems. You can easily follow the instruction and recover your data. Just follow the link below:
http://www.freedownloadmanager.org/download/portable-ext3-data-recovery-5481163.html
Click on the download link for the .exe file and it’ll take 6mb (approx) space of HDD.
Next time please try to open the flash drive by right click on it and click explore. Don’t double click on the flash drive.
Good Day.
Hello Carlson,
You are absolutely right. It’s the perfect solution for backing up the system. Basically, its feedback is awesome and the people who are affected by the virus are also like it. Whatever, you can get different tools but I think Raise Data Recovery is the best which you get from this http://download.cnet.com/Raise-Data-Recovery-for-Ext2-Ext3-Ext4/3000-2094_4-75207052.html website. After all, you can search for Google for getting forums so that you can participate in the FAQs. Hopefully, it can help your problem be solved.
Thanks!
