I need a powerful data converter IMG to ISO
Hello Amb,
I understand your problem. IMG to ISO conversion is very easy. You can take help of software that are available on the net free.
I am recommending you some software which you can use to convert IMG to ISO.
MagicISOMaker, ImgBurn, ccd2iso. These three are best soft to convert image file to ISO.
Hello Amb,
Here is the best and free software which can convert your IMG files to ISO files instantly. You can also burn your ISO files with this software alone. This amazing software is called MagicISO. If you do not have this software yet, here is the download link:
MagicISO 5.5 build 281 – this version added many features that will help you with faster and more reliable conversion of IMG files to ISO files.
Here are the steps for conversion:
1. Install and open the MagicISO software.
2. In the Menu bar, Click “Tools” then click “Convert”.
3. A dialog box will appear then browse the file that you want to convert.
4. Choose the output format.
5. Click convert.
You are done! You’re file has been successfully converted.
I hope this helps.
Notifications
