I need a PowerPoint slideshow lock
Hello expert, I am using MS Office 2010 on my PC. I have some important PowerPoint presentations. But in my home all are using the same computer. So I need a PowerPoint slideshow lock to keep individual of my work. Please can you help me on this task?
Answered By 0 points N/A #164730
Hello
This is how you can lock Microsoft PowerPoint; Click the office button then select save as; secondly, click Tools Buttons where you will select General option on the pop-up menu to install your password. Fill in your password in Password to Modify text box. This causes others to need to provide a password in case they want to edit. You can click the ok there after and fill in the open password you entered earlier and click save button in the save as dialog box then click yes.
