Samshu
Posted on - 09/25/2011
I am using Microsoft Office 2003. I need to print mirror text (Readable in mirror) about ten words. I am using hp1020 laser usb printer. Is this possible in my system with microsoft office 2003 and with the said printer?
jhayson
I need to print mirror text.
If you have an installer CD just follow the step-by-step procedure. You can also download the printer installer online. Once it is installed in the computer, it can print anything.
When it comes to mirrored text, you won't be able to directly type a mirrored word from MS powerpoint or MS word.
But you can do it using the WordArt. You can open WordArt in MS Word then choose the font and color which is closest to your desired outcome. Next, type the word and click okay. The text will then be displayed on your screen. You will have to use the Drawing toolbar to rotate the image. Right click on the image after activating the drawing toolbar then choose the option Flip or Rotate, then Flip Horizontally.
