I need a program to run Java on my iPhone
I need some help here. I can’t seem to open Java files on my iPhone. I tried installing it but no success. So I’m kind of lost what’s going on. Do I need  a certain program to run Java on my iPhone? Any help would be greatly appreciated. Thanks guys.
Best Answer by Marshall Kwak
Answered By 5 points N/A #189575
Hello James J Khan,
You need to download a special apps for using Java in Phone. You need to download and install the Cydia app in your iPhone. Now form Cydia app go to installed package tab and find "iPhone/Java" . You can alternatively find "iPhone/Java" by searching Java in lower right side of the apps. Now install "iPhone/Java" in your iPhone. Now you are ready to use Java in your iPhone.
Hope this will help.
Answered By 15 points N/A #189576
Hi James J Khan,
This option allows you to run Java files from your iPhone without the use of Jailbreak. This is thru an app called "Cloudbrowse".
The app is available from the appstore for a particular fee. This app also allows you to access flash content using your iPhone, iPad and iPod. Usually these contents that use flash/java such as games, video and other media is disabled in IOS.
Here is a screenshot:
