I Need a proper realtek volume mixer
Hi guys!
The sound of my speaker is not working although it says that the realtek is fine.
Can someone help me on what proper realtek volume mixer to use so I can fix it?
It`s kind of annoying that I have tried several drivers but still don`t work.
Answered By 0 points N/A #158737
Hello Dear,
Thanks for sharing your problem with us. Dear it is not possible to install just mixer on your system.
Sometimes it is installed but not work properly.
This will be installed and work properly only when it is installed along with the updated version of the driver.
Kindly update your driver with the latest version.
You should try Realtek HD Audio Driver Version 2.70.
You can download it from here.
I hope you will be understood.
Thanks
