For my ram I need less consuming antivirus to take less memory on it, but it has to be very secured same time. I like to play games on my pc, and its model is some outdated, including average condition of ram, so, I need that. Please give me the site of that antivirus.
I need ram less consuming antivirus
Hi Dear Campbell Parker,
I read your question and understood your actual problem.
Dear there are many Antivirus software that use very less amount of RAM and works better.
I will suggest you to use these two Antivirus software.
Panda Cloud
Avira
Panda cloud is very good antivirus for the low Ram computers. This works better even get low space to load on RAM.
You can download it from here.
Panda Cloud Antivirus.
On the other hand, Avira Antivirus is also good but it take larger amount then panda cloud. I suggest you to use Panda Cloud.
You will enjoy its working.
Thanks
If you want an antivirus program that consumes less memory, you should try ESET Security Products. If you are still using the outdated Microsoft Windows XP and Microsoft Windows Vista, you can install ESET Smart Security 8 because this is the last version to support these operating systems. ESET Smart Security was now replaced by ESET Internet Security which supports Windows 7, Windows 8.x, and Windows 10.
Unfortunately, ESET Smart Security 8 is no longer offered as a download on the ESET home page. If you are using Windows 7, Windows 8.x, or Windows 10, you should try one of these from ESET:
- ESET NOD32 Antivirus 9 – for 32-bit Microsoft Windows, download 32-bit ESET NOD32 Antivirus 9. For 64-bit Microsoft Windows, download 64-bit ESET NOD32 Antivirus 9.
- ESET Smart Security 9 – for 32-bit Microsoft Windows, download 32-bit ESET Smart Security 9. For 64-bit Microsoft Windows, download 64-bit ESET Smart Security 9.
- ESET NOD32 Antivirus 10 – for 32-bit Microsoft Windows, download 32-bit ESET NOD32 Antivirus 10. For 64-bit Microsoft Windows, download 64-bit ESET NOD32 Antivirus 10.
- ESET Smart Security 10 – for 32-bit Microsoft Windows, download 32-bit ESET Smart Security 10. For 64-bit Microsoft Windows, download 64-bit ESET Smart Security 10.
- ESET Internet Security 10 – for 32-bit Microsoft Windows, download 32-bit ESET Internet Security 10. For 64-bit Microsoft Windows, download 64-bit ESET Internet Security 10.
- ESET Smart Security Premium 10 – for 32-bit Microsoft Windows, download 32-bit ESET Smart Security Premium 10. For 64-bit Microsoft Windows, download 64-bit ESET Smart Security Premium 10.
- ESET NOD32 Antivirus 11 – for 32-bit Microsoft Windows, download 32-bit ESET NOD32 Antivirus 11. For 64-bit Microsoft Windows, download 64-bit ESET NOD32 Antivirus 11.
- ESET Internet Security 11 – for 32-bit Microsoft Windows, download 32-bit ESET Internet Security 11. For 64-bit Microsoft Windows, download 64-bit ESET Internet Security 11.
- ESET Smart Security Premium 11 – for 32-bit Microsoft Windows, download 32-bit ESET Smart Security Premium 11. For 64-bit Microsoft Windows, download 64-bit ESET Smart Security Premium 11.
