Pedro Mahons 10 points N/APosted on - 02/11/2013
I would like to use an animated GIF image then loop them frame by frame to create a realistic waterfall in flash. Can I overlay a static image to another layer using Photoshop? Can someone teach me to make this work? Thanks.
Since you never mentioned which action script version you prefer, I just searched for the best tutorial, and thought a video tutorial was best. I have found this YouTube video tutorial that demonstrates step by step how to create a water fall effect using flash.Â
Yes you can create step by step on how to create the water fall effect using flash. In this regard you have to follow the procedure, I have found from the video :
Please visit there due to solve your problem. I hope you will find a way .
1....
