I need Regclean pro Help
I have a regclean pro, I want to know how to use this software.
I know basic tools, but I don't know some great tools in it.
So please tell me how to use this software.
Hello Larry
Regclean Pro is an advanced tool to improve your system performance by fixing some internal errors. Regclean have two types which are free and pro.
Regclean Pro fixes the following issues
Its features are Cleaning invalid registry errors increases application response times and it provides complete undo functionality. A full backup of the registry is taken before fixing registry errors so change can be reversed, only if required. You can simply clear errors from the outside of the window by just clicking the clear the errors found.
Hope you get the answer
