I need repair tools of samsung HDD software
Hello everyone,
I need some repair tools of Samsung HDD software. I search on the net but there is none any trusted source. Can anyone suggest me a good link of it.
Hello everyone,
Hi Cassandramariannaa,
You can get many suggestions on the Google for your Samsung HDD repair tools. Just go to Google and write “Samsung HDD repair tools”. You already mention that you need trustable website ok I am giving you website link. I think it is a treatable website because I never face the problem when I access this website.
Here the link for you-
http://samsung1.software.informer.com/download-samsung-hard-disk-repair-tools/
You can watch on YouTube about HDD repair tools
Best of luck
Dear user,
You can visit the official website of Samsung, which is https://www.samsung.com/us/ for your HDD repair tools and other software. However, I have done a research for your query via Google and have found some websites for you. Here are the website URLs:
http://www.tomshardware.com/s/samsung+spinpoint+hdd+software+tools/
Hope this will help you.
Thank you.
Hello Cassandramriannaa,
There are plenty of repair tools that you can get.
Please go to the following site, from you can download and learn about its installation, setup instructions and all,
Trusted Official site,
https://www.easeus.com/data-recovery/other-recovery-software/hard-drive-repair-software.htm
I hope these solutions would help you to fix your problem.
Thanks,
Checking or fixing problems on your hard drive can be done with any disk utility application. Microsoft Windows has its own disk utility included in the system. This is the cheapest and easiest way to check errors on your drive. To try this, start Windows Explorer then right-click the drive you want to check and then select “Properties.”
In the properties window, go to “Tools” tab then click “Check now” under “Error-checking” section. On the next screen, check “Automatically fix file system errors.” If you want to check for bad sectors, check “Scan for and attempt recovery of bad sectors.” When you are finished, click “Start” to begin checking the drive.
The length of the scan will depend on the size of the drive and the number of errors. Another way is to use the command prompt. Press the Windows key + R to bring up the “Run” dialog then type without quotes “cmd” and then hit Enter. In the command prompt window, type the following command then hit Enter:
chkdsk [drive] /f
Replace “[drive]” with the drive letter of your target drive that you want to fix. For example:
chkdsk c: /f
To see all available options you can use, use the following command:
chkdsk /?
When you are finished, just close the command prompt. Another way is to use third-party software like PC Tools Performance Toolkit.
