I have some questions before purchasing Revo Uninstaller Full 2012 version. Does it have the registry key access and can it delete left over data after regular uninstall which the add or remove programs can not do? I'm on a Windows 7 64 bit system.
I need Revo uninstaller full 2012 feedback
The Revo Uninstaller is very easy to use and it is very powerful program. It has an Advanced mode that enhances specific program Registry access to your context menu. It has Optimizer that grasp the Autorun Manager, Windows Tools and Junk Files. It will help you in removing programs and unwanted software installed on your computer. And best of all, it can help you remove unwanted files, folders, registry keys and more that commonly left over on your PC.
You can download it from the link below:
https://www.revouninstaller.com/
