Emaily Rawa
10 points
Posted on - 12/13/2012
Hello fellows,
I need a sample jQuery interview question.
I am willing to study online or get a softcopy about jQuery interview questions for my case study report to be submitted next week.
This is not an easy project since I have to get different kinds of opinion about programming and technical issues especially on jQuery.
I need everybody’s comments and suggestions.
Emaily Rawa.
I need a sample jQuery interview questions.
 Let's see some more jQuery interview questions.
JQuery is a library for client scripting or server scripting?
JQuery is a W3C standard?
What are jQuery Selectors?
The jQuery html() method works for both HTML and XML documents?
Which sign does jQuery use as a shortcut for jQuery?
What does $("div") will select?
What does $("div.parent") will select?
What is the name of jQuery method used in an asynchronous HTTP request?
What is CDN and what are the advantage of loading jQuery framework from CDN?
How to load jQuery locally when CDN fails?
Some of JQuery interview questions include:
Explain what JQuery is.
Why use jQuery?
In JQuery, what meaning does the dollar sign ($) carry?
In jQuery, body onload () function and document.ready () function is used. What is their difference?
Outline the steps followed when using jQuery in ASP.Net project.
Explain what JQuery UI is all about?
Outline the common features of JQuery.Â
What common programming constructs can be done using JQuery?
Outline and explain the methods used in JQuery to create effects?
How is JQuery different from Java Script?
Explain the different types of selectors used in Jquery?
Outline the advantages and disadvantages of JQuery?
Outline the method used to select all elements in a page using jQuery.
Thank you.
