I need Samsung galaxy tab 2011 driver
I'm having problems upgrading the latest driver of my Samsung Galaxy Tab 10.2 Dual Core. My PC would not detect my Galaxy since upgrading so my choice is to roll back to the 2011 driver. Where can I find Samsung Galaxy Tab 2011 driver? I'm on Windows 8.
Answered By 5 points N/A #171099
Hi Paine,
If your driver does not work in your Samsung Galaxy Tab 10.2 Dual Core. I suggest you to use Samsung Kies. This application is developed by Samsung to have a communication between almost all of the Samsung mobile phones and Samsung tab.
Tablet computers and Windows or Mac. It is just like a universal driver for almost all of the Samsung mobile and tablets. Samsung Kies has been just like iTunes on Apple software.
Here are the direct download links for Samsung Kies (For Windows and Mac):
Samsung Kies for Windows
Samsung Kies for Mac
I hope this helps.
Answered By 590495 points N/A #315258
If you want your computer to detect your Samsung phone so you can freely connect your phone to your computer, you don’t need to install a particular driver. What you need to install is the PC software of your phone. To fix the problem, download Samsung Kies and install it. This is the only program you need to connect your phone to your computer.
Samsung Kies installs the necessary driver for your Samsung Smartphone which allows the computer to detect your phone when you connect it via the USB cable. For Samsung Smartphones running on Android 4.3 Jelly Bean and higher, download Samsung Smart Switch. For other Android versions, use Samsung Kies.
