I need SharePoint 2007 network audit tool
Hello, I am going to create some website about internet marketing. So I need sharepoint 2007 network audit tool. I have to create professional site. I know the HTML code basically. Experts please help to resolve this. Thanks.
Best Answer by Farmer Yardley
Answered By 35 points N/A #164121
Hi There,
You can surely create a website using SharePoint and even publish it. It can also be used as a content management system. You need to have a good knowledge of HTML and XSLT for maximum gain. I would recommend w3schools.com for learning HTML.
You can try SharePoint here- https://products.office.com/en-us/sharepoint?legRedir=true&CorrelationId=91953a87-9ea3-41e4-bcd7-1e9efda620e7
Answered By 0 points N/A #164122
The best solution would be to learn the HTML for SharePoint 2007.
It's not a perfect solution, but it should work.
You can visit this website for more details:
https://blog.mastykarz.nl/which-mime-type-to-use-in-sharepoint-2007/
You should be able to learn all you need to know about SharePoint 2007.
Just visit that website for more tips, tricks, and tools.
