I need a simple procedure on how to penetrate Skype
Hello! I would like to know how to penetrate the skype but would like to be directed on the simple procedure of how to go about it. I am new to skype and would like to use for my odesk jobs. I would like to get elaborate description of the procedure but in really simple terms. Any assistance will be highly appreciated.
Answered By 130 points N/A #162884
Hi Kurt! If you are wondering how to use Skype, here's how simple it is:
1. Create your Skype account here which could either be connected to your Facebook account, Microsoft account or just a separate Skype account. You have to verify your Skype registration with the email address you added there.
2. Download the Skype application software for your computer from HERE, Skype can work in Windows, Mac or Linux.
3. Once the downloading is installed, open the Skype installer which is a .exe file and the installation will go on.
4. When you are done installing, you can login to your account and start using Skype.
You can chat in Skype. You can also use the video and audio conferencing with the aid of a webcam.
You can use Skype in odesk.com as your reference for communication purposes.
