I think my hard drive got corrupted or damaged so I can't access my files anymore. Is there a soft recovery HDD program where I choose what files to recover? I'm still in a Windows XP 64 bit sp2 system. Thanks in advance.
I need a soft recovery HDD program
Dear Braxton,
Hard drive recovery software will works as long as the drive is detected in BIOS or under disk management. Otherwise, drive with mechanically damaged Signs won't shows up In your system and thus data recovery would be impossible.
Stellar Phoenix Partition Recovery would be perfect software for you to recover almost any type of media files from problem hard drive. Recovery options like Advance Recovery or RAW recovery can efficiently scans the drive and shows files in recoverable situations.
Download program from here: https://www.stellarinfo.com/windows-data-recovery-professional.php
Hope it helps!!
